modified bosch motorsports injector from fic?
Old 07-18-2014, 09:48 AM
scotte's Avatar
Default modified bosch motorsports injector from fic?
*****this thread is not the place to start another id vs fic vs other debate
if you want that do some searching you will find plenty of @#@# to read*****
so i ordered a set of fic 1000's (60mm tall ev6 plug)
i received a set of bosch motorsport 48mm extended tip injectors with a red lower spacer to make it 60mm and an ev1 plug
the tip of the injector shows tool marks from some modification
the tail end of the bosch part number is ground off but looking at several i can make it out to definitely be 0280158123 which pulls up to a bosch motorsports injector that flows ~600cc (stock) with all the same dimensions
i called fic and they were very professional and said they sent the wrong injectors but they were a more expensive injector ($92 ea) and i could either keep them and they would send me some ev6-ev1 adapters free or swap them out
they emailed me the data sheet (labeled fic 1000)
anybody have these? results?? ease of tuning??
Attached Thumbnails modified bosch motorsports injector from fic?-20140718_104430_resized.jpg   modified bosch motorsports injector from fic?-20140718_104442_resized.jpg
Old 08-16-2014, 02:49 AM
Ws6Dnero's Avatar
Those look nice
Old 08-20-2014, 02:15 PM
Ws6Dnero's Avatar
127lb bosch injectors
Old 08-20-2014, 02:54 PM
scotte's Avatar
nope they are 95lb (1000cc)
Old 08-29-2014, 02:59 AM
ducatisl's Avatar
I run FIC 95's, 48mm body, EV6, tune just fine, idle to WOT, using their supplied data.
Old 08-29-2014, 04:55 AM
Iam Broke's Avatar
FIC 95's here as well, had to scale the E38 ECU tune for the flow data 80% to keep it within range. Runs fine dialed in with their data.
Quick Reply: modified bosch motorsports injector from fic?
