02 camaro will not start after racetronix pump install
I recently installed a racetronix fuel pump and car will not start after install. I am getting voltage at the relay, i hear the pump primp but it had no pressure at the rail, pressed schradder valve and no gas. I only put about 4 1/2 gallons in because i have a 5 gallon gas can and also if i needed to drop it if it did not start. I know they recommend 10 but 4 1/2 should start it right?
I just dropped the tank again, everuthing looks ok, if the regulator is bad or that black sensor would that orevent fuel to the rail, i could hear the pump priming, i am at a lost. I have switched out relays. This is what it was doing before i replaced the pump.
LS1TECH Sponsor
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
Assuming you finished the registration process your account will be approved and help on this topic can easily be found.
__________________
>WEB SITE<
>WEB SITE<
Also waiting for my account, purchased my pump 10 years ago & no longer know the part number (very important for registration) so I looked up the current number for my car & entered that, they took offence to the erroneous info. I just registered a few days ago so I could browse for help so hopefully they will open the door for me.
I'm having a similar issue, but mine is just slow to crank after Racetronics fuel pump upgrade. It'll eventually crank, but it just takes several seconds after it's been sitting for more than 10-20 minutes. Racetronics, I just registered to your forum. I'll check it out as soon as an administrator approves me.
