Returnless Fuel Pump 2006 Sierra
Don't know if anyone can help me on here, but I had a question about returnless fuel pump install for my Sierra. I purchased the 255 pump from racetronix for my truck, and after looking over the install instructions from the Magnusun supercharger kit, it looks like I can just remove the factory pump and install the new one, with out any modifications to the bucket. I was worried about the factory venturi system, but It seems that it fills from a different location, and not the pump specifically? So the bucket will still get filled even with an aftermarket pump? Can anyone confirm this?
I pulled some pictures from the instructions so you guys can see. Looks really straight forward. I just read all these return style install, and I see them cutting up the buckets to get the sock through, but if I don't have to do that, then id rather not.
ALSO, I see theres a brass fitting in that kit, which I don't have, but I will just reuse the stock one, and cut the hose off and re install new hose.
