Starting my 800+rwhp fuel set.. Questions
Old 10-17-2014, 09:50 AM
transamfreak01's Avatar
Default Starting my 800+rwhp fuel set.. Questions
Looking to start doing my fuel system now. I have a plastic tank and was wondering what you guys think about running twin walbro 450s? Car will be a turbo set up and I found a thread where the second pump turns on in higher boost.
Do you guys think this is something I should do or should I just buy a metal tank and run an external pump? I no there's a ton of sponsors out there too and I've contacted a few but I'm looking for other advice. Thanks guys
Old 10-18-2014, 03:12 PM
maroonls1z's Avatar
800 should be doable with twin 255s
Old 10-29-2014, 02:45 PM
2muchboostNY's Avatar
800 on pump or E85?
Old 10-29-2014, 03:16 PM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
Can get a lonnies system which is in tank.
Old 10-30-2014, 10:37 PM
94LS1B4C's Avatar
That setup should support 1,000 on e85
Old 10-31-2014, 12:40 AM
ws6turbo's Avatar
I have triple walbro 255 and 726 wheel on e85, had two in there and they maxed around 600 wheel on the Dyno, so the place tuning it added one more wlbro 255 , my injectors then were maxing out at 726, and bam that's where I'm at.
Now, when i go around corners on less than half tank it sputters, so I'm takin them pumps out and going with aeromotive a1000 intank
Old 10-31-2014, 07:39 AM
94LS1B4C's Avatar
what size feed line are you running?
Quick Reply: Starting my 800+rwhp fuel set.. Questions
