Fuel lines in the way
Just got a set of truck coils and they aren't fitting on tje driver side with the fuel lines, mainly the purge valve line is in the way, how can i re rout them or delete them all together?
I hope i can explain what i did in a way that is understandable. Here it goes...
Take the coils off of the bracket and rotate them 180 degrees. you will have to take the wiring harness out of the bracket also and rotate that 180 degrees. You can mount that on the valve cover, a couple bolts will line up correctly, but not all, you dont need all of them. This will put the truck coils in the same spot the ls1 coils were and give you all the clerance you need. I wish i had pictures.
