What injector part numbers?
I am looking for a set of GM 36#, or Ford 42# Green Top injectors or a set that will plug and play with my current set up.
I have a '03 Avalanche, with a stock wire harness and brain. We swapped out the 5.3 for a 6.0, bigger cam and better flowing heads, and re-flashed the brain accordingly. I have the stock truck style intake and fuel rails from the original '03 motor.
What are the part numbers that I need for the GM 36# and the Ford 42# injectors?
Thanks for looking.
All set now, thanks for he replies. I ended up with a set from Precision Turbo & Engine. These are the same ones that I have http://www.primetimeperformance.com/...?prod=17113738
Thanks for looking.
I am interested in the Ford ones, seeing how the LS3 ones are sold. What body style and connector style are they?
I live near Clarkston, Mi., how can we meet, or would it be better for you to ship?
The more I have researched, the more I have found that my requirements need to be adjusted.
However, flintwrench69 told me that Lingenfelter makes a spacer kit for the rails, (or you can do this https://sites.google.com/site/sloppy...torspacerhowto) and there is a kit to easily tag on the correct injector plug. ("http://www.ebay.com/itm/Fuel-Injector-Adapters-Delphi-Wire-Harness-to-EV1-LQ4-LQ9-LM7-L59-LM4-L33-/271795296500?hash=item3f484318f4&vxp=mtr")
Fortunately for me, I am doing the ls swap on my '96 Impala SS, so no need to buy injector adapters, I'll just use the original plugs from the '96 harness. The injectors are a set I originally had in my SS, a close friend of mine now owns them, he had them sent out to be inspected and cleaned, and haven't been used since. So, I will be owning them once again. LOL!
I have a '03 Avalanche, with a stock wire harness and brain. We swapped out the 5.3 for a 6.0, and re-flashed the brain accordingly. I have the stock truck style intake and fuel rails from the original '03 motor.
Thanks for looking.
Thanks for looking.
Russ Kemp
Russ,
No, I am not looking for stock injectors for either. They do not make injectors for a 5.3 or a 6.0 that will work. I should have put in that the motor has a better cam and heads, that the need for bigger injectors. I'll add it to the original post. That is why I am looking for a higher lbs and flow.
