80s, Twin Walbros, -8/-6 Lines enough for 750rwhp E85?
I'm just contemplating running an E85 setup on my higher compression motor with a D1 @ 12psi or so with methanol injection.
Would Siemens 80s, Billet Rails, Twin Walbro 255s, and PTFE -8/-6 lines be enough for E85? I think I could hit 700-750 with 11:1 CR motor and 12psi with decent timing with the D1.
I think you might be better off with a fic/id1000.
The walbro 340 is a 255lph pump. I'd use that as a primary and and then one of their bigger pumps (400lph if sticking with walbro) on a Hobbs switch/relay set for xPSI.
It's possible the dual 340s (255s) could work if you backed the pressure down to 3bar with a a manifold referenced regulator. That would be right to their limit though.
SD 80# Cobrajet
FRPP M-9593-LU80
Siemens 80#/hr @ 3 bar
Dual Cone Ford Cobrajet OE Injector
That's from Banish.
80 lb/hr, single-hole, high-impedance fuel injector with USCAR electrical connector
Single cone spray pattern
Original equipment on supercharged FR500CJ Cobra Jet
Thats the same PN from FRPP website. Dunno.
FRPP M-9593-LU80
That's from Banish.
