what do i need for ls3 injectors on a ls1??
its not exactly as the title says but here's the scenario. i have a WS6 that im swapping a LQ9 in with the factory ws6 wiring harness, injector plugs, sensors ect. now i bought ls3 heads bc i have a larger bore so i can fit the heads. with that obviously i needed a ls3 intake, and so on to ls3 style injectors which i believe are the shorter ones. will the same ls1 injector plugs/connectors plug into the ls3's? or do i need some sort of kit? hopefully that makes sense to someone. thanks for any help guys.
