02 fbody return system retrofit Evap??
Hey guys so I removed my fuel tank and went with a fuel cell now I'm going back to a two pump solution in my stock fuel tank.
That being said my car is setup for a return system and I removed the Evap when I had the cell in.
I want to use the charcoal canister on the stock tank that's part of the Evap system but I'm not sure I can retrofit it since I don't have any Evap equipment left.
What do you think? Has this been done?
I have the return system in right now. Just using a fuel cell and external pump which will not be switch back to the stock tank with lobbies double pumper and an fittings.
Everything will swap fine but my only concern is the the evap line on the hat and also I am wondering if I could use the evap Lina which go to stock charcoal canister and then vent or what my options are...
