Summit E85 Fuel Lines?
I use their lines for nitrous wet shot fuel supply and as a fuel rail cross over with no issues on E85. As long as they are teflon (PTFE) lined then you can use it without problem. Also, since they are lined, they don't stink the garage up like gas.
Summit has a PTFE lined SS hose.
Thanks guys for the input. My thought too was that as long as they were teflon lined they should be fine. With my fuel fittings alone cost over $200(All Redhorse brand), if I could save a few bucks I could. I didnt expect the lines and fittings to be so expensive.........
Whoa, gotta make sure your fittings are compatible with Summit line. The PTFE thickness and actual OD can vary between MFGs so you sometimes have to run matched line/fittings. If you have to run Summit fittings they are also quite a bit cheaper but the anodizing doesn't look quite as nice, the black in particular.
Do research of the Summit line of fittings. You might save a dollar up front, but the threads might get fubared and you end up purchasing twice.
Summit will allow you to return the hose more then likely. General rule of thumb... stay with all the same manufacturer when assembling AN hose/fittings.
1. "i used the summit ptfe lines. god help you if you try them. im not sure if its there fittings or the line itself is slightly oversize but the ferrels are almost impossible to get on. i use fragola -10 which went together easily. the summit -8 was a nightmare"
2. "Summit fittings they are also quite a bit cheaper but the anodizing doesn't look quite as nice, the black in particular."
Tried this junk on a recent project...JUNK. We're local to Summit, so we took it back, got Fragola, and had no issues.
The sales guy at Summit had no problem w/ us doing the swap...Had he seen that before??
You can get the Fragola PTFE hose on Amazon for $5.79/ft for 15 feet of -8. The Fragola fittings are a little cheaper than Summit also. Check the Vibrant brand stuff on Summit for all of your non-hose fittings like Y-blocks and ORB stuff. They are quite a bit cheaper than Fragola.
I have been using the Summit E85 hose and so far no issues. Not the teflon stuff. Its only been on the car for about 6 months but the inside of my rails were spotless.
I have had good luck with Summit fittings. Sounds like the teflon stuff is problematic but the standard Summit AN fitting are very likely private label Fragola or Earls.
