Software Edit Required to Run LS2 TB on LS6??
I just upgraded to a FAST 92 intake manifold and have an LS2 throttle body ready to be installed (with the adaptor harness). I was planning to run an adaptor on the new 4-bolt manifold so my factory TB would work, but it won't with the spacer fit due to the location of the power steering fluid reservoir.
The plan was to drive the car to the shop and then install the bigger injectors and LS2 TB to avoid any sort of issues before the car is tuned.
Is a software edit required to run the LS2 TB on the LS6, or is it plug and play with the adaptor harness?
