return style fuel pressure
Im running a return style fuel system with 2 intank walrbo 450lph pumps. Second on at 5 psi with -8 feed -6 return. Whats the draw back of running lower base fuel pressure say 43 instead of 53. The truck only has a base tune so before I start getting into it I wanted to know what the pros and cons are. I run a 43 base in my syclone with 30 psi. Cant I do the same with an LS engine..
I run 72lb Bosch from FIC and I do it at 58psi because he told me the spray pattern is much better at 58psi due to it being a LS style injector.
