Help! Main postive geonded out now feul pump wont work
Old 04-29-2016, 12:40 PM
jesselywiski's Avatar
Default Help! Main postive geonded out now feul pump wont work
Ok so i was street tuninng and things got hot under the hood and the main positive goin to fuse box touched my turbo and grounded out the car shut off and then would only crank not fire my fuel pressure gauge shows zero so ive narrowed it down to that .. ive checked all fusses relays and grounds under the hood any advice would be helpful
Old 04-29-2016, 07:18 PM
LS1-450's Avatar
Check all inside cabin fuses & relays, as well. Check fuseable links. If no fuel pump, a link wire, main or fuel pump related fuse or relay is blown.
Quick Reply: Help! Main postive geonded out now feul pump wont work
