Help pick an injector for my twin turbo setup
Twin turbo LQ9.
58 psi.
Should be able to support 900 rwhp.
Tuner likes 80# Siemens Deka but in his experience, they are good for 750 rwhp reliably.
Basically looking for something a bit bigger that has good data available to tune off of. Needs a good idle as this will be a street car.
58 psi.
Restricted User
I've been pushing the Deka 80s a lot higher than 750 whp.
The secret? Run more than 58 PSI of fuel pressure. I had 85-90% duty cycle at 20 PSI with 58 PSI. Turned it up to 68 PSI, now I run low 70s duty cycle.
And 'reliably' doesn't really come into question with power and injectors. Whether they are running 15% duty cycle or 85%, they aren't any less reliable.
Twin turbo LQ9.
58 psi.
58 psi.
If you want bigger quite a few places sell 1000cc, 1300cc etc etc. As long as the tuner isnt stupid, idle will be fine.
Restricted User
If you're going to run static, run as much pressure as you can without killing the flow of the pumps. Before, I was running a 42 PSI base and 26 PSI of boost, so 68 PSI of pressure at max boost. After blowing off the reference line a couple of times and realizing that it idles fine at 68 PSI of pressure, I couldn't find any reason not to just run it at static that way.
Deka 80s top out around ~750whp at 58 PSI static depending on fuel pump.
Who has the best prices on the ANSU or ID injectors.
Feel free to PM me if they aren't a sponsor. :p
So if I'm running a dual Walbro 450 lph setup with FAST rails, would I still have a fuel issue that would limit me to 750 rwhp?
-8 an supply. -6 an return.
If injectors cannot flow at your desired pressure, then all the fuel pumps/lines in the world are not going to change that
And given it sounds like you have a proper return system and FPR in use...it's also pointless not boost referencing the regulator to maintain injector flow relative with boost.
