I need some help with injectors
Old 08-30-2016, 10:13 PM
Austinbelair's Avatar
Default I need some help with injectors
Quick question. This is my combo on an LS swap into a 66 Chevy C10 so far:
2004 Corvette LS1
243 Heads
BTR Stage 4 \Truck cam
1-7/8" long tubes
FAST LSX 92 intake
FAST anodized fuel rails
Corvette regulator
Ported LS2 Throttle body
Will 36lb injectors work well or should I run 42lb? And with that combo, I need EV1 style LS1 injectors, correct? or do I need an LS2 style?
Is running a MAF better with a 411PCM and drive-by-wire setup? I need to order a custom harness and need to get these details sorted.
Old 09-13-2016, 09:33 AM
carpenterbruce9's Avatar
I believe LS1 is fine.
Quick Reply: I need some help with injectors
