pics of aftermarket fuel feed lines?
Old 02-22-2017, 10:45 AM
conde'strans's Avatar
Default pics of aftermarket fuel feed lines?
Anybody have pics of how they setup an aftermarket fuel feed line? I have an Aeromotive fuel regulator setup on the driver side wheel well and already have a -6an return line setup all the way back to the Aeromotive 340 fuel pump. I am considering doing a -10an feed line and completely replacing the stock one. Although I had read that the stock feed line is good up to 1,000 hp somewhere and my car will be around 500 NA (maybe spray 150 later on).
I want to see how the -10an feed line would be setup or routed into the fuel rails and along with the vacuum line that goes along with the stock one. Anybody sell this kind of setup already? if not I'll buy everything separately.
Old 02-22-2017, 04:12 PM
Majestic9C1's Avatar
not really sure if this is what you are looking for.
Old 03-03-2017, 03:32 PM
^ sure thing! how did you run the feed line all the way to the pump? how did you route it?
Old 03-04-2017, 01:14 PM
It uses the stock metal lines that run under the car.
Quick Reply: pics of aftermarket fuel feed lines?
