Can AN aluminium fittings be used on steel line?
Old 03-31-2005, 03:50 AM
GTS346's Avatar
Default Can AN aluminium fittings be used on steel line?
Can you use Hard tube AN fittings on steel fuel line? It says for use on aluminium line everywhere, but doesnt say if it can or can not be used on standard factory steel lines.
Anyone ever done so without leaks?
Old 03-31-2005, 09:57 AM
618HAWK's Avatar
Ya not a problem, you can use a standard AN fitting-either Steel or alum on either a steel or alum line.
Old 03-31-2005, 02:27 PM
GTS346's Avatar
Thanks hawk, also do u know if you can put 90 degree bends in aluminium tube when making fuel lines or does it fracture the line?
Old 03-31-2005, 06:07 PM
oange ss's Avatar
yes you can, stainless steel is another story
Old 04-01-2005, 09:19 AM
618HAWK's Avatar
Aluminium and stainless can have 90 deg bends, it all depends on the radius of your bender and type of bender you use. The tighter the radius the more chance you take in making a flat spot in the radius.
