guys with the 30lbs SVO Fuel injectors! HELP
Old 06-04-2005, 02:12 PM
350 LT1's Avatar
Question guys with the 30lbs SVO Fuel injectors! HELP
I have got 30lbs SVO fuel injectors on my LT1 and the car is runing with too much fuel in the engine ! I have got LT4 hot cam kit, forged pistons, 52mmTB, headers + cat back.
Do i have to program my car? What is a good Program i can go with? Will it work fine after i program it?
or should i go with accel 26lbs or STOCK fuel injectors?
Old 06-05-2005, 03:39 AM
smoknta's Avatar
Have you had it retuned? If not you will need to. Mostly for the injectors and cam. Try PCMforLess, they are pretty good. They are really reasonable on price to.
Old 06-06-2005, 05:25 PM
Beast96Z's Avatar
Your stock injectors will support the mods you have. I would put them in immediatlly if you haven't already. If you don't, you may wash your rings out and there goes a pefectly good shortblock. If you want to keep them, send your comuter to PCMforless like smokn said. He does good mail order and he can get you were you need to be.
