dropping the tank
dropping the tank
I need to change out my fuel pump, and in order to do that, it involves dropping the exhaust, tank, and rear axle. Also involves removing the hind quarter panel, according to the chilton's manual. Has anyone else had to do this? If so, do you have any tips before I jump into this? Thanks
The rear-end does not have to be removed to drop the gas tank. Just have the car up on a lift, or on tall jack stands. The rear-end just needs to hang down by the shocks, and once the cat back exhaust system is removed, and the tank straps unbolted, the fuel tank will slide out with a little encouragement. Bob
