Smells Very Rich with No Fuel Pressure
My car stumbled and misfired, wouldn't hardly run and died when I gave it gas. My friend hooked up his tek II and it showed high injector voltage and a high MAP sensor voltage. He said the injectors were dumping tons of fuel in and it smelled like a lawnmower. I can hear the fuel pump working, but have basically no fuel pressure at the fuel rail. This doesn't make any sense to me. Does this problem sound familiar to anyone?
Originally Posted by 92CamaroReallySlow
Sounds exactly what happened with my car...my fuel pump was bad. Replaced it and it runs fine now, fuel pressure is back and not misfiring.
yea my pump was getting louder and higher pitched than it should have. And my car would die if i gave it gas. Same symptoms. Its still working its just not working very well. And because its misfiring the unburnt gas is being pushed out ( I think).
Thanks for your replys......I sure hope this works. I've been screwin' with my car for a week now trying to find the problem. That does make sense what you said about the misfires and unburnt gas. My car was misfiring and stumbling so bad it would barely run. It looked like I had a couple of fauled plugs also.
well if you have bad fuel pressure, the plugs didnt cause it. I would bet the fuel pump is goin. Is it a stock pump? how many miles? The only other thing is a clogged filter or some other blockage in the fuel lines. Does the pump seem louder than usual?
I was thinking that maybe the unburned fuel was causing the plugs to foul. It probably is the fuel pump though. It is stock and has many miles on it. Even if it's not the pump, it probably is due for a replacement. I just changed the fuel filter today and it didn't really look that bad. I'd say the pump sounds similar to how it was before the problems....no major difference. I thought it maybe sounded a little loud the other day, but I was also low on fuel. Before my car totally went to crap, I did experience some hesitation a couple of times and pulled a misfore code. Then one day it just started bucking and misfiring like crazy and I barely made it to the side of the road. I couldn't keep it running because it would die when I'd give it gas. It sounded like I just installed a t-rex and had the coil packs on backwards lol.
I just fixed my problem! The pressure hose that goes from the pump to the sump inside the tank swelled up and fell apart! I was getting 20psi at the rail and the car ran like crap. Its the hose that holley sends with their pumps to which is the crazy part/
Yes its probabily something simple. Did you recently instale an aftermarket pump and use a regular black hose as the pressure hose inside the tank? If so BAM theres your problem!
