Max psi without a reg, Walbro GSL392?
Old 09-29-2005, 05:09 AM
GTS346's Avatar
Default Max psi without a reg, Walbro GSL392?
Just wanting to know what max psi a 255LPH GSL392 pump would have if the reg wasnt hooked up?
Reason being is I just want to test fire the engine for a few minutes getting everything going as it may sit another 3 months.
Old 09-29-2005, 07:35 AM
Coal Mining Director
onfire's Avatar
If you have an open return without a regulator the pressure will be very low without the regulator as a restriction. It will make the tune off....
Old 09-29-2005, 02:48 PM
GTS346's Avatar
Will it run at all?
Quick Reply: Max psi without a reg, Walbro GSL392?
