Fuel setup
Old 10-07-2005, 11:54 AM
72short_cut's Avatar
Default Fuel setup
im putting a 99 ls1, into a 72 Chevy Short box. im starting the fuel sytem, ive got the holly 12-920 external fuel pump, and running the Gm corvette fuel filter regulator part# 10299146. which will be mounted in the frame rail, coming from a rear mounted fuel tank with a top supply feed line. im also going to mount a pre filter before the fuel pump recommend by holly. i was wondering if there was any concerness or issues with the set up im going with.
thanx
Old 10-08-2005, 08:54 AM
Fran D's Avatar
Is the rest of the LS1's fuel system stock? If so, I'm not sure you're going to get enough rail pressure (58 psi) with that pump.
