Best budget fuel system for 600-650 whp?
I will be installing the Hi Flow turbo base kit with a 70mm turbo for about 600 rwhp and would like some suggestions,opinions on a fuel system upgrade please. I do not want to spend more money than I have too. I was thinking about just getting the racetonix intake pump with the wiring harness and a KB boostapump and some 60lb injectors will that do the job? Will I have to replace the stock fuel rails? Like I said I do not want to spend money if I don't have to. Opinions please.
It depends on what regulator you go with. Figure a Aeromotive will be around $130 ish and the new line and misc fittings for it will be about the same amount.
Matt
Matt
Originally Posted by 52172
Does the pressure regulator with return cost much? I might as well get them if it is hit or miss along with new billet fuel rails.
