How much can the stock fuel pump handle?
Old 10-12-2005, 12:37 AM
MountainMotor's Avatar
Default How much can the stock fuel pump handle?
Just wondering how much hp the stock fuel pump can support on a '98 WS6?
Old 10-12-2005, 07:12 AM
Coal Mining Director
onfire's Avatar
around 400rwhp na.
Old 10-13-2005, 09:48 PM
bigdsz's Avatar
With the mods listed below my fuel pressure dropped to 42# at high RPM's. A Racetronix Plug and Play resolved that issue.
Old 10-14-2005, 12:39 AM
Bombguy99z28's Avatar
It will handle a bit more than 400rwhp. I sprayed a 125 wet shot on my almost stock at the time camaro and fuel pressure was fine, 432rwhp. It can vary from engine to engine, truthfully. If you plan to see more than 450 at the wheels I would definately upgrade, if you think you will be in the 400-450 range you could probably put the car together and check your fuel pressure, you might be able to get away with the stock one at that power level.
Old 10-14-2005, 12:51 AM
ninobrn99's Avatar
420 or so at the wheels but i know if your spraying a 150 shot or more, you'll need a bigger one!
