Stock Fuel Rails - Full Fuel System
Ok the title is wierd, but I have a 3-gallon fuel cell, A-1000 pump, and a A-1000-6 Regulator. I want to use the stock rails. How do I set this up.
For the life of me I cannot remember who its done. I do know that there is a fitting to hook up the stock fuel lines to -6an.
I do not need rails because I'm down on power. I just dont want to have to buy them if I don't need them.
the stock shrader valve is -4an i believe.
but what are you planning on doing, welding fittings to the end of the rails to run to the regulator?
spend the 129 on some nasty performance rails, less hassle. with that you could run the feed line then Y it to both rails, then off the rails to the regulator to return.
thought that was about the only way to do a pump/regulator setup...
or......
or......
Ive heard that I could do this
Tank -> Filter/Pump -> Regulator(Mounted in the back by the pump and tank) -> Rails
