Fittings.....
Fittings.....
Want to buy fittings for plumbing ,fuel and misc. other lines. Is there some kind of chart that explains what the different "AN" minus whatever means??? Like what size those numbers are equivalent to? For example : "AN -1 or -10". ??
AN = Army Navy specification
it is a fraction of 16 for the OD of a metal tube
Example:
-8 AN = 8/16" = 1/2" OD of the metal tube but equals 0.440 ID
http://216.242.145.16/products/content_p.phtml?pk=68
This should move to a different forum though...
Example:
> " 'AN' ( Army-Navy) Sizes were established by the Aerospace industry years
> ago and were designated O.D.(outside diameter) of the rigid metal tube that
> each size fitting is used with.
> The numbers assigned equate to the O.D. of the tubing in 1/16 inch. Since
> tubing and hoses are found with assorted wall thickness we can now
> understand that the designated size number does not necessarily tell you how
> large the inside diameter will be. (For example, the inside diameter of an
> Earl's size 6 hose end is nearly as large as the inside diameter of some
> other manufacturer's -8 hose ends.)
> Each AN size number has its own standard thread size."
> The technical section then goes on to explain the standard SAE thread sizes
> of each AN size. There is also an explanation of NPT thread sizes.
Originally Posted by Boostaholic
Oh, and I think that this thread is off topic for the section it is in, when a simple google search can find the answer to your question there is no need to put it in advanced tech.
