2000 LS1 fuel rails
2000 LS1 fuel rails
I am installing a 2000 LS1 in a 56 chevy and was looking into what will have to be done to make this work using a frame rail mounted fuel pump. My questions are simple like what adapters are needed to mate up to the quick snap connectors for the fuel lines and how many fuel lines do I have to run to the front of the car to make this system work. Also places where I can find these parts would be helpful. Thanks
We have billet fuel rails that would make your setup easy. You need to run a feed and return line that the stock rails do not offer. Give me a call and I can help you figure out your system.
Nate
Nate
Do some searching in the hybrids section, there are alot of options available.
One is: using Russel tube - AN adapter fittings on the LS1's hard lines, running AN hose and using a 'vette filter/regulator (this solves some of your return line problems if your LS1 only has one line coming off the fuel rails). Somebody makes a billet (I think) adapter that snap connects to the fuel rail fitting and allows you to run AN hose off the other end, but the ones I saw at the time were spendy.
Some stuff I saved when doing my hybrid:
https://ls1tech.com/forums/showthrea...ight=fuel+rail
