help...car wont start
went to my car to start it and it turns over but wont start. I have a 2001 z28 A4. Turned the key to ON and did not here the fuel pump kick in. My question is what is the location of the fuel pump fuse and the fuel pump relay on the 98-02 models. Also, if it is my fuel pump does anyone have recommendation for good fuel pumps under 350 dollars?
Fuel Pump Relay - Underhood, electrical center 2
I/P Fuse block - behind left side of dash
Underhood Electrical Centers - left front corner of engine compartment.
You will see them clearly labeled. How many miles on the car? Any work done to it recently? You can find fuel pumps for less. Your car not starting could be one of many things. Do you have access to a scan tool?
