Fuel system questions..
I have the dual walbro pumps now and I have been told I need to get high flo rails and regulator. I am pushing right at 76psi max on a mechanical gauge with the stock rails.
My question is what would be a good choice for a fuel pressure regulator?
Thanks guys!
Thanks guys!
Originally Posted by MIGHTYMOUSE
i think you should try some fuel injectors first if you have a lean condition that all that fuel pressure is not able to overcome
If im going to get an aftermarket regulator, I might as well go the rest of the way and finish the system.
Thanks for the help guys!
i gotcha now.. i was just trying to make sure someone wasnt trying to sell u something just to sell you something
while i still dont think you need rails at your hp level.. if your stock regulator isnt 'regulating' then i agree you should at least replace it, if not upgrade to the one that speed inc. sells. everyone has good luck with those. if you are going over say 650-700rwhp in the future then you might as well get the rails and run a larger pressure line.
