Which vacuum referenced FPR for 2003 Z06
I'm working on dialing in my mototron 60lb injectors for my setup. It idles rich, so I want to dial down the fuel pressure at idle.
My Z06 has the "second half of the year" fuel system, so I am unsure which regulator to buy.
Thanks!
Tommy
Thanks!
Tommy
Originally Posted by Nasty N8
There is no reg. for the stock fuel system you have to add a return style system. The stock reg is in the tank.
Nate
Nate
But what is the regulator looking thing on the fuel rail itself?
Tommy
Originally Posted by TaTommyWS6
Thanks Nasty. I thought that was the issue. I wish I has an older car
Tommy
Tommy
its suppost to keep the pressure more consistant between injector firings..
you dont even need it though. if you use aftermarket rails, you wont even have it anymore.
