What part is this?
What part is this?
I wanted to know what the black cylinder looking thing is on the driver side of the engine right next to the fuel rail? It has a tube that goes into the front of the intake right behind the TB. Thanks! It has a really loud tick to it and wanted to know if this is normal.
Sounds like the evaporative emission canister vent solenoid. Are you setting any codes?
Matt
Matt
Matt
Matt
Nope, if there are no codes it sounds like yours might be a bit noisier then some of the others. The Tick you hear is the solenoid opening and closing.
Matt
Matt
Do you have access to any scan tools? If you do you should be able to tell rather quickly if it's an injector or not.
Matt
Matt
Thanks for the info! I fear i may be hearing a bad injector b/c this all started right after i used Seafoam...
