Quick Question About Aeromotive Fuel Pump
Old 12-27-2005, 08:56 PM
trucksleeper's Avatar
Default Quick Question About Aeromotive Fuel Pump
I put a aeromotive pump on this weekend and it makes alot of noise is this normal or could something be wrong with the fuel pump?
Old 12-28-2005, 05:31 AM
GTS346's Avatar
How is the pump mounted, if its mounted solid to metal eg no rubber between the pump and metal it will buzz like a king bee.
If its got rubber insulated around it then thats the pump, live with it.
I think its mounted solid though?
Old 12-28-2005, 08:53 AM
Fire67's Avatar
Most all high flow aftermarket pumps make alot of noise... Just one of the things you get used to in your quest for speed.
Old 12-28-2005, 06:00 PM
Its mounted solid but it sound like a Honda Civic running in the back seat.
Old 12-29-2005, 08:20 AM
Lethal Injection's Avatar
1)Is it a new pump or used?
2)Are you pulling gas to the pump by having the pump mounted above the tank or is it below the tank?
3) Do you have good voltage to the pump?
If you do not have a controller for the pump that would be what I would do first. This will save you headaches from the pump noise and the pump failing at a later date. If this is a street car I would not run the pump without one. Also make sure you have the right filter on the inlet side. You can read about this on the Aeromotive site.
