intake
Originally Posted by PAUL SIZEMORE
i have a ls2 ls6 intake i would like to put on 2001 ls1 eng what all do i need to have to make it work. thanks
I was told the LS2 intake is "the piece" to use for boosted engines. You have to modify the cam sensor and knock sensor wiring. The LS2 intake does not work well in NA engines. Im running turbos, and stuck with the LS6 intake. The LS6 is hard to beat, even with the 75mm TB!
intake
