the last fuel system you will need
whats up guy? i just installed the last fuel system that i will need as long as i stay all motor which we know won't be for that long. I used a tank out of a 98 camaro so i could sump the tank with 2 1/2 inch ports in the sump.
From the tank to A1000 fuel pump 12 AN line.
From pump to a Y block under the hood i used 10 AN line.
Out of the Y block i have 2 8 AN lines one to each fuel rail
Out of each fuel rail i used 8 AN lines to the reg.
From the reg back to the tank i used 6 AN line
As soon as i add some boost or nitrous to it i will be upgrading the pump or if i use a fogger i will be installing another system.
yea that will be the last fuel system that i will need in that car that is my eveyday driver to and from work and where ever i have to got when i bild a race car that woun't be the fuel system in it.
