Fuel Injector Help!
Fuel Injector Help!
Just finnish installing heads and cam along with 42lbs injectors and when I turn the key with out starting the car I noticed that the injector closest to the driver is spitting out fuel from the top or the bottom at least from what I can tell its coming from the injector itself or somewhere around there, its hard to tell. What can be wrong???? Help...
A couple ideas...
2. If not the case, then the other posts suggesting a pinched o'ring is likely. Suggest you use some "sneaky creme" on the rings when you reinstall.
