8-160#s or 12-90#s
OK, how much power? Boosted i'm assuming?
If you not spinning that high (7k isn't that high ) you can usually get by with 8 96's for alot. Assuming this isn't alcohol.
You can bump the base fuel pressure to get by on 96's, but that will ultimately find the limit of your pump.
8 160's will get you well over 2k HP at static flow. However, that will drop as your RPM increases just from the simple fact you can't get enough fuel in one engine cycle. (That's why I ended up moving to 160's from 96's)
