MSD Boost a pump
MSD Boost a pump
How do I hook it up? I would like to know wires to cut into and such if anyone can help I'd really appreciate it. Also where did you mount it, Back by the spare tire area?
Wolfee
Wolfee
I'm guessing you are doing this on an F-body....C5 shoud be similar.
Find your fuel pump relay (should be close to your fuse panel somewhere under the hood) and install the BAP inline after the pump fuse. On the C5 the fuse box is in the same location as the battery box, so I hooked up the BAP and installed the electronics and controller in the battery box area.
Hope this helps.
Hope this helps.
