99+ tank swap help please! Doing this tomorrow!
I have to drop my tank tomorrow so I can install my new 6 point rollbar, so I figured it would also be a good time to install a 99+ tank on my 98 TA. I got the tank off a member here at LS1tech. What I need to know is, what else do I need to get the new tank installed? Is the ring on the top the same? Can I take my pump/level transmitter assembly out and bolt it right in the new tank? What about the EVAP cannester stuff? I think I need to order a filler spout as I didn't see one with the one I bought. Any and all tips will be greatly appreciated!
Thanks
Thanks
I'm working on weight savings now, that's all. From what I've researched, the 99+ tanks are 18+ pounds lighter. And I've practically done everything else to my car, weight savings is the only thing left. Besides, my Racetronix pump was starting to get weak already, so I had to pull it to replace with a walbro 340 anyway.
I did find the filler spout in the tank last night though, so the only major question is, can I get the in tank pump and fuel level bracket to work on a plastic tank?
