Need Some Advice.
Need Some Advice.
I need some advice on what fuel system to go with. I'm running a H/C ls1 with a 200 shot. Would a Racetronix kit work with bigger injectors are am I gonna have to run a new fuel system. Thanks
Originally Posted by Matt@HSW
It'll be borderline, but if you run a front mounted regulator you'll prolly sneak by. How much total HP? Another option might be to run a stand alone fuel system.
Matt
Matt
I'm wanting 650-670 to the tire on the bottle.
Could you explain more about the front mounted regulator? (newb question)
You would be relocating the factory fuel pressure regulator from the original position (above the fuel pump in the fuel tank) up to the fuel rails. You would then run a new return back to the fuel tank. It would help stabilize fuel pressure and would be good to around 650 rwhp.
Matt
Matt
