Problems
Problems
Installed motor and go to crank car no gages but the starter turns over, go to stick an OBD II code reader and all the gage lights came on, went to crank car cranked right up, alright finish up everything today and drive it down the road go down turn around start comming back gave is 1/3 throttle go threw first second third coast, well the car needs tuned bad so the car dies... Try to crank it back up nothing... well the gages show up but the starter wont turn over....
So my question is What made the car do this? What could be done to fix this, Open to suggestions
Bryan
Bryan
check for proper fuel PSI at the rail first, be sure to check for disconnected electrical connectors and be sure they all have tight connections. This is a good starting point.
