fuel pump and filter
lookin to upgrade some fuel stuff. startin with the pump and the filter and ideas. after that will move into the lines and injectors. but if i could get some ideas that would be great.
well i'd have to say the best starting point would be to upgrade your stock fuel pump first. you have a few options, many people like to go w/ the walbro in tank units, most vendors have them in stock and if you look into racetronix they offer a plug n' play kit that is very easy to install, you might want to also look into the "hotwire" kit to supply voltage to that pump. as far as filters go, i've had good luck w/ the stock filter, but then again im not sure as to when it'll actually become a restriction in your fuel system. then from there injectors, adj fuel press. regulator and so on. the lines and rails themselves can handle a decent amount of power so depending on your plans w/ the car itself would justify swaping them out for some aftermarket pieces.
goodluck, any other questions feel free to pm me.
