98-99-02 fuel pump assembly are they interchangeable ?
Old 09-19-2006, 06:39 PM
APU6speed's Avatar
Default 98-99-02 fuel pump assembly are they interchangeable ?
I ordered a used fuel pump assembly for my 98 and when it cam in it looked slightly different. On the unit that came out there was noplastic housing really around the pump and on the one that I got there was. Also there was one line thatdid not connect to anything on the assemble up top but rather only on the bottom. Is that some sort of in tank breather hose ? Are the 98 wiring harnesses and the 99-02's interchangeable. Will my pmp assembly and sending unit run if it was mistakenly a 99 -02 unit that i got ?
Old 09-20-2006, 01:24 PM
connexion2005's Avatar
From what I understand yes, they are.
Old 09-20-2006, 02:14 PM
Doc
Doc's Avatar
