injector size on stock cube single 76 gts?
any idea what size injectors to run with a single 76gts , heads cam , stock compression , 15 lbs max boost ?
looking to run in the high 9's !
and should I use a maf or do SD tune? what map ?
Coal Mining Director
I'm running high nines at +140mph with Mototron 60lb injectors with some room to grow. A 2 bar map #12580698 from GM will work fine to 15psi. Now pick your choice of EFI Live or HPT for a custom 2bar SD operating system and you're set.
