What fuel system upgrades are needed for Heads/cam and a dry 100 ?
Just wondering what I would really need to spray a 100 dry shot on my heads and cam car. My car probably has about 430-440 hp at the wheels. I have a racetronix fuel pump in it already. I am mainly concerned with the fuel rail and the stock injectors. Thanks
A single racetronix pump should be fine. However, when doing the tuning i would watch fuel pressure. To be safe, throw a boost-a-pump on it or a second pump in the tank. This way you will have more then enough fuel when the nitrous bug hits. If your spraying a wet shot the injectors shouldn't matter, however that is near the limit of the stock injectors.
What goals do you have for the motor in the future? If you plan on going with larger ci , i would reccomend some 42lb just beacouse you can get them pretty cheap. The stock rails are plenty for a while. If you up the shot quite a bit, it may be wise to get a fuel cell from harris or the similar.
