Got sent the wrong pump can I still use it
OK so I am workin on my dual intank install. I already have a single racetronix pump and I adding a second walbro pump. I was told to order a GSS3340 pump. Which I did. But speed inc screwed up and sent me a GSS341 I think the difference is that the GSS341 has the verturi feed thing on top. Can I still use this pump or should I send it back and get the one I wanted. I am just pissed cause now I will be held up another week or 2 if I send it back. Any help would be great
The 340 and the 341 are EXACTLY the same pump as far as flow goes but have different inlet and outlet configuations to allow install in different cars. If you are going to try to keep the jet pump use it if not send it back and exchange it
Mike
Mike
Venturi feed will not keep up with the flow of dual pumps you should use 2 340 pumps and drill holes in the bucket and get the pickups out the bottom of the bucket.
Nate
Nate
