Fuel rails and injector size???
I'll be putting heads and cam in my Trans Am this spring, along with a Fast 90 intake and NW throttle body. What is the best rails to use and what size injectors should I use. I'm planning on a nitrous system in the summer. Any help would be greatly appriciated. Thanks in advance.
You'll find some rails are tapped (npt) pipe thread, and others use -08an o-ring fittings. I prefer the o-ring type because I think they look cleaner.
From my research, it doesn't look like any of the rails are better than the next. I read about a few problems with Aeromotive as far as the mounting tabs, so I think i'm going to go with FAST rails.
