Can one Walboro 340ss handle 525 rwhp?
Hey guys lately I've been noticing that my fuel pressure had started to drop from 60 psi. to 56 psi. under normal driving. It will go to 48 psi. if I go full boost so my question is can one pump handle the the rwhp or is something wrong. The diffrence between the last fuel pump and the one I installed is that when I turn the ignition I used to see 60 psi and then it would level off to 40 psi. before I would turn the car on. The fuel pump I have now I see the fuel pressure needle go to 60 psi. then drop to 0 psi on ocassions. Then when I crank the car the pressure goes to 60 psi. and stays there until I turn the car on. Any help is greatly appreciated I'm getting a little tired of this.
