my dual walbro setup has burnt up!
so here is what is going on guys i go to look under my car and i see that all of my fuel electrical line's look burnt up. all the plastic tubing covering the lines is burnt as well! there is a on going tape deck rewinding sound coming from the rear area near the lines! i filled the tank yesterday and gas started shooting out of the fill area at 24.00 dollars when it cost me about 38 to fill it. i was on E prior.....then i got in the car and it said i was at 3/4 tank
possibility's what it is.......
exhaust leak....we looked over and found nothing
exhaust burning the lines and tubing covering them ..
TANK NOT FELLING UP.....I dont know
Melted insulation is caused by too much current - usually because of a short circuit. It is possible that the short circuit is inside one of your pumps but more likely, current is flowing where it should not. In either case, you need to find the short and eliminate it, and replace the damaged wires. If you lack electrical knowledge and experience, you need expert help.
