retrofitting lt1 into carb'd gbody- fuel situation
hey everybody. im dropping an lt1 (fi) into my 86 monte (carbd) and i want to keep the fi. i know this has been done many times, but i cant seem to find specifics on what is done to feed the fuel from the tank. i have heard i need to swap to a fi gbody gas tank, but they are difficult to come by and expensive brand new. what can i do to keep my current tank and will it work as well as a fi gbody's gas tank? would i be running an inline fuel pump outside of the gas tank? recommendations on fuel pumps? fuel injection is totally new to me so please explain like you are talking to a dumbass (in this case you really are ). thanks everybody
Get a fuel sender for an 86 monte with 4.3 tbi. The stock tank will work as long as you keep it above 1/4 tank. Any lower and you might have problems with fuel pickup when you go around a corner. I am running a Walbro 255 pump in my tank with that setup. By the way, this really needs to be in the conversion section. You will probably get more answers there.
Hey nice to see some LT1 Montes I bulkhead fitting the bottom of the tank for a pickup and returned in the top. Im ganna change that and tap another AN8 in the bottom for a return.
