Do I have enough Fuel?? What do you suggest??
setup will be a 408 w/ L76/L92 topend.... about 520-560rwhp NA... 200 wet shot of nitrous thru a TB plate..... for now. No hardlines.
42lb SVO injectors
Custom rails
I planned on installing a Racetronix pump.....
Do I need an Inline pump as well.... what else?
Down the road I plan to go 300-400 shot Direct Port, switch to a Single Plane Carb Style Manifold.
What setup do I need to support this?
42lb SVO injectors
Custom rails
You will need a whole lot more fuel than a Racetronix kit. I have a few ideas for you give me a call I can set one up for your needs.
http://www.nastyperformance.com/FuelSystems.html
Nate
Nate
Originally Posted by Forteen3GT
more cash then I have... more fuel then i need.
1 gal Jaz cell in the front with a holley blue or black pump and regulator. run it to your fuel noids and jet accordingly. Much safer this way!
Originally Posted by V6 Bird
Leave the racetronix in the tank, no in line pump and do it on motor.
what pushes the fuel to the noids??? I am not following ya on this one. I understand the concept of a stand alone..... but what makes pressure????
